'91 RS gfx on '82 bird
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Will they fit? I like the way they look, and they might be good for making air dams for the rear brakes. Just a thought. Opinions?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Everything but the nose gfx will fit.
The camaro has a seperate gfx piece and the firebird nose is one piece deal.
With a bit of hacking you could get it to work,, sort of,, it depends on how much work you're feeling up to to make it work.
Also keep in mind also the camaro nose gfx has part of the front air inlet molded into it as to where the t/a (or firebird front doesn't
Da Boid![](https://www.thirdgen.org/messgboard/smile.gif)
- 4 out of 5 people think the 5th is an idiot
[This message has been edited by deadbird (edited December 27, 2000).]
Da Boid
1 Post
Honestly, I like the way it looks right now the best. Personally, I think it's the best looking (body style) of all years. Not that I don't like all other years, I just like mine the best.
