Remove rocker panel ground effects - 91 TA
Prepping for paint.
How do I get to the studs holding the Trans Am ground effects to the rockers? GM manual shows two in the front and one in the back, but no advice on how to get to them.
Figured it out...
Need to remove the front wheel well liner for the front studs, and the interior trim panels (by the back seat) for the rear stud.
To get to the studs for the rear quarter ground effects, remove the "glove box" in the inside of the rear compartment.
Figured it out...
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Remove rocker panel ground effects - 91 TA
Remove the kick panel and the rear lower interior panels and there are holes in the body, probably covered with sheets or black rubber tape material. You can get to the studs throuth those holes
Thomas
Exterior Parts for Sale
21
10-07-2015 05:33 PM
Thomas
10-03-2015 05:34 PM
92firebirdchris
08-14-2015 11:56 AM
