91-92 front air dam mounting...
Are there any differences in the mounting holes from an 85 IROC and the 91-92 Camaro? I have a factory front "air dam" and want to mount it to the front of my 85 IROC, but think the newer part needs small "slits" cut into the fenders. Can anyone help here? Hopefully I am making sense...
http://sc3gfb.org/members/jason.html
91 Camaro TPI, 355ci. Sportsman 11 heads, LT-4 Hot cam,Pete Jackson gear drive, on,and on, and on... 13.6 @ 102.5 with a 2:73 open rear, no traction, no tuning, no practice.
the front facia should bolt up, but you are right, the 91-92 fenders have slits in them. when i swapped my 87's facia to a 91-92, i just cut those plastic pieces off and just bolted it on to the inner wheel well. i didn't want to buy new fenders for that; mine looks like any other.
good luck
thadd47
good luck
thadd47
Thanks, does the air dam flex at all without the tabs? I figure I could either do as you did, or take measurments from my 91 and cut the slits in the 85 accordingly.
1991 Camaro TPI, 355ci. Sportsman 11 heads, LT-4 Hot cam,Pete Jackson gear drive, on,and on, and on... 13.6 @ 102.5 with a 2:73 open rear, no traction, no tuning, no practice.
1985 California Edition IROC red, polished TPI and polished wheels, otherwise completely stock 305ci. & automatic trans.
1991 fullsize Blazer 4-wheel drive, 350,700r4, Pro Comp lift, K&N, TBI spacer, 3" Catco cat, 3" cat back Flowmaster, etc....
1992 Trans Am
05-10-2023 07:19 PM
Mutillator
Exterior Parts for Sale
10-01-2015 06:05 PM
