Black Seatbelts for 1989 Camaro.
I am looking for the #'s that are printed at the bottom of a pair of black seatbelts on a 1989 camaro. The dealer says I nead this # to get some new ones or to find the part #'s. Can someone type me the #'s or does anyone know a GM part # for new black seat belts? The # should be something like GMXXXXXXXX Please help my tan seat belts look ugly with a grey and black interior.
1989 Iroc-Z TPI 350 auto 4-spd Removed MAF screens K & N filters, stock other than that.
Sorry brother, you're SOL on black ones, they've been discontinued. You can still get grey ones, but only grey. If that'll work for your interior, good on ya! I got grey ones for my red/black interior and spent a good amount of time trying to get them black - no dice. I have the numbers for an '88 Trans Am, not your Camaro, but if you need them let me know and I'll get them to you. You can get these belts through Dal at VanDevere Pontiac for about $46 each.
Email me if you need more info,
Darth Steve
Steve's Trans Am Temple
Darth Steve
What is the phone # for VanDevere Pontiac? Does anyone know the part #'s for the grey seat belts, and are they still easy to find? Thanks for all the reply's.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Check the classifieds section. Someone might be sellign a set. If they dont have them, go to http://www.thirdgenresource.com . they might have some.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
LG4-Based Chevy 400
700R4 Tansmission
3.23 Posi Rear
100WX2 Amp
His number is (800) 362-9494 or his email is lockitup@bright.net - make sure you tell him you got his number from the thirdgen internet site so you get his discount. The drivers side number is GM12392910 and the passenger side is GM12392909. Now be aware these are the numbers for the 1988 Trans Am - if they aren't the same as the Camaro you're screwed. It may behoove you to go find a junkyard Camaro the same year as yours and just check the seat belts for the correct numbers - maybe their the same, maybe not. All you have to do is pull the seatbelt out as far as it will go (the bottom part), there is a tag at the bottom that has the GM number on it.
Hope this helps,
Steve
Hope this helps,
Steve
Roblyons
Interior Parts Wanted
08-30-2015 12:07 PM
