IROC Fog Lamps
classic industries, year one or any of the thirdgen classifieds.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
1 Post
Car: 89 IROC-Z
Engine: 383
Good luck getting those fog lights new. They cost $75 each and then the mounting hardware and brackets are even more!! I got mine straight from GM with my discount from work. You can get them from Next Gen or other aftermarket thirdgen companies.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
--RPM Racing--
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
Re: IROC Fog Lamps
so I have GM fog lamps, does any1 know the best bulbs like a nice white bulb maybe LED that will fit inside a GM fog lamp?
Re: IROC Fog Lamps
I've experimented with various LED lamps, most have a strong blue tint, maybe not a bad thing but sure not right. Be interested in what you find.
mustangman65_79
08-11-2015 03:17 PM
