weather stripping
Car: 89 camaro iroc, 89 camaro rs
Engine: 350-iroc / 305 rs
Transmission: 700r4 / t5
weather stripping
ok so im looking at weather stripping seeing as mine dosent seem so be changed ever. but i was wondering whats a good place to get it. i want to do the whole thing and it has t tops
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Re: weather stripping
They are not too bad to do, just that replacing the hard top weather stripping is a lot less work.
i've used soffseal before for my 82 hardtop and never had a leak. regreting buying the cheapest set for the 82 t-top tho. just pulled they all off because they were still leaking, but..... found other problems so the weather stripping may have been ok.
I just bought the Soffseal for my t tops. I haven't installed them yet, but a side by side comparison with my mint original weatherstrip on my TTA shows promise. They seem to be almost identical.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I used Soft Seal also on my TA, absolutely no problems whatsoever.Just make sure you take your time and do the preparation right!!!it's all in the prep.And may I make a suggestion!buy the whole complete replacements, T Tops,doors,hatch,inside sweeps with the new plastic sill & outside window sweeps,etc.I got the whole kit from 1A a while back,I don't know if it is still available in a kit.
Sorry,the weatherstripping I used was Metro "Super Soft" not Soft Seal.The results are still the same.
1A sells Metro. I got the Soffseal t top seal set with the seal that goes on the t top itself. It was a 4 piece set that I bought from Summit. I bought a Metro hatch seal which looks really nice. I bought GM outer sweeps because I heard differing opinions of the aftermarket ones. My inner sweeps are still in great shape. I bought a Soffseal cowl seal which I am a bit disappointed with because the clips need to be inserted in the seal.
The door seals are from Fairchild industries. I bought them because they have a plastic insert on the ends where they screw in. I can't give opinions on the stuff yet because my car is still in paint prison.
I still need to buy the drip edge for the t tops. I am debating whether to buy the plastic or rubber ones.
My only recommendation at this point is to stay away from OER. I have heard nothing but bad things about those t top seals.
I think most of the time when t top weatherstrip gets a bad review, they were not installed correctly. Like Mantaguy said - it is all in the prep. Also, be sure to use plenty of adhesive. Here is a good Youtube video from a board member.
He is installing Metro seals -
http://www.youtube.com/watch?v=Aoqy-tWmR0k
We carry weatherstrip for your Chevy Camaro. Here's a link to them on our website if you would like to check them out. Chevy Camaro Weatherstrip
3.8TransAM
10-01-2015 08:47 PM
