Urgent help needed!!! My trunk done goofed
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
Hello,
I was just leaving college and I opened the trunk on my IROC to put something in it...Then when I went to close it, IT WON'T CLOSE!!!. The pulldown motor isn't working!! I tried pushing it down (cause I did a search and some people say that sometimes it gets stuck), but it didn't do anything. I had to drive home with my trunk half open cause I only had a little bit of rope to tie it down....
Is there ANY temporary fix I can do to temporarily close to until I can find out what's wrong? I rely on this car to take me to college and work everyday omgz
Any help appreciated.
Thank you
(tl;dr - Pulldown trunk motor isn't working, trunk won't close, what's a quick temporary fix?)
Thank you
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
Re: Urgent help needed!!! My trunk done goofed
If it worked before, it will probably still work. With the hatch open (there is a micro switch there) put your finger or a srewdriver all the way to the back of the mechanism on the car to make it lift up then make sure that the latch for the hatch hook is open. If not lift the latch with a screwdriver while using the key release.
My motor sometimes goes into some type of protection mode. I'll have to unhook the battery for a minute or so, and then when I hook it back up. I'll hear the motor kick on.
But when it's stuck down, it will not re-latch. I have to get it to reset before I can get it to latch again. I need to figure out what is going on there.
1 Post
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
I've been having trouble with mine from time to time. what I do is just jiggle the wires that attach to it (it helps that I took off the rear trim to fit my sub box). Has worked every time for me thus far.
1 Post
Car: '88 Trans Am GTA
In '08 I had my slides shatter causing the motor to short out. I tossed the damn thing out and made my own bracket.
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
About 4 years ago my hatch motor kept pulling the hatch back closed every time you opened it unless you were quick enough to help pull it up before it had the chance to close it again?? Got tired of that, so I disconnected all the electrical to it and bought a tube of that liquid steel and blocked the slide rails with it to keep the motor from moving. Now the hatch works like a regular hatch.....turn the key and the hatch pops up! PERFECT!!
1 Post
LOL I had that same exact problem on my first bird. So many "effin A" moments with it pulling back down . never did figure it out.
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
I heard that it had to do with the hatch glass being so heavy which could damage the latch by slamming it, so you lower it easily and the motor did all the work closing it???
TDS -Top Down SoLuTions has a soLuTion for $300
some 3rdgens have plastic units ... some have metal units ...
typically you donT need a rebuilt unit ... you just have to figure out
how it works for your particular situation i.e. how to operate it ...
seems sometimes like they have a mind of their own
Car: 1991 Z28
Engine: 5.7 TPI
DON'T SLAM IT! You will just break it if you haven't already. Check beside the latch- there should be a little plastic lever beside the jaws.. Press down on it and see if the motor winds it back up. Them close as normal. If not, check for a blown fuse. It that is good, email Lon at Top Down Solutions for help, BUT DO NOT SLAM IT. The motor housing is just plastic and you will break it. I think the plastic motor housing was designed to be the weak link, rather than burning out the motor or causing a wiring fire or something...
it sucks if you reach in to pull it up and it is drawing down on your fingers... ask me how I know
I had just had the car for a short time. Drove my son to the bust stop. Realized the light was on in the back hatch area. Popped it from inside with my son in the car (idling). then it didnt seem to go up and I reached deeper to get more leverage. I heard the motor and both hands were stuck more with each second. The motor kept going... I begged my son to pop the hatch. he was like which button?? meanwhile I am in pain and there are moms in SUVs waiting too and I am sure having a good laugh!
He finally found the button ("dad there were a lot of buttons!") and I pulled out my bruised hands... could barely shift home.
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
I just slam Mine... plus you dont want the latch mechanism working... you might accidentally press while going down the street XO
Car: 1992 Z28 Heritage Edition
My hatch ONLY pops open with the release if it's over 75 degrees outside. Otherwise, the weight of the hatch pushes it back down and re-latches it within 2 seconds or so, which means I have to stand behind it with the fob in my hand so I can immediately lift up on it to keep it from re-latching.
I had initially tried a larger spring piggy-backed on top of the factory spring for latch, which worked great for a few years. Unfortunately the extra stress wore the latch out, so I'm now back the factory setup which only works when it's hot outside.
Yeah I can look back on it and laugh but it was majorly painful and embarassing. I mean it was like the first week I had the car and my son didnt know where things were. One day, when i go to the great race track in the sky, it will be his so he better learn!
colton_carlson
03-08-2019 12:21 PM
