Shaved Door Handle Kits
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I have found a kit that I want from searching on here. Before I buy it, just wanna make sure that you can unlock you doors from the outside with the remote. The kit is Vehicle Power Accessories 81160-35DP from summit racing. I have looked and I cant figure it out. I know it operates the door release, but what about the door locks? What else would I need?
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: Shaved Door Handle Kits
It's your car so do what you want, but why do you want to ruin a 3rd gen like that? Shaved handles do look nice, but are a huge PITA-I know I have had them before.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Well i should've been more specific, lock/alarm type. Where I work, I would like to have an alarm lol. And I'm just going for a clean show car look with a daily driver.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
And in case I accidentaly lock the doors from inside
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
yes, so just remove the linkage from the interior as well?
Car: 1989 Pontiac Firebird Formula
Engine: V8 5.0 305 TBI
Transmission: 700R4 with B&M MegaShifter
Axle/Gears: Gear Ratio: 2.73 Ring Gear: 7 5/8
dctrouant1995 - Please document everything you do on your Door Handle Shave project. Lots of pictures. I could use a good reference. I have future plans to, remove the trim, shave my doors handles and front and rear marker lights before I re-paint it, as soon as I can get access to my cousin's body shop. My Bird is a daily driver also.
What about Lambo Doors? If you're a Kenny Powers fan and ever watch "Eastbound and Down" the Dodge truck has Lambo Doors and they are always fighting them, Hahaha! - I digress.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I actually am going to do lambo doors, one day, right now plans are shaved door handles, shaved antenna, remove body moldings, mold the fender and hood vents in where there is no gap in them and a reverse operating hood!
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
What size selonoids are you going to use? the ones in the kits are usually to small. be sure to add a switch outside the car somewhere in case your remote takes a dump. I have had them on two of my past cars, they are a novelty at first than you do get tired of them, good luck with the project, post some pics
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
45 pounds. If it does I'll just crawl in thru the hatch. I will as soon as I get the kit. Hopefully should have everything by the end of june. I'll be painting it viper yellow with orange and green pearl/flakes mayb
1 Post
Car: 91 Z28
Axle/Gears: Stock
So true. I had them on a convertible S-10 back in the day. They were really cool the 95% of the time they worked....the other 5% consisted of prying the windows away to fit a broom handle to open the door from the inside. Definitely need a mechanical backup.
Car: 1986 Trans-Am
Engine: 305 5.0 TPI
Transmission: 700 R4
Axle/Gears: 2.73 posi
I too have wondered about locks for shaved door handles. It makes sense to remove the locks but how do you keep your car and everything inside of it secure?
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
That question always gets me. If you have no handles what is the need for locks?
What do you mean keep everything secure?
It is secure because there is no other way to get into the vehicle other than by a remote or by breaking the glass.
You can break the glass when there are locks on the car correct?
So why the need for locks? You tell me...
Its redundant to keep the locks on a car with shaved door handles.
Terrell351
06-13-2021 01:13 PM
