1991 Camaro fuel tank
Engine: 5.0 TBI
Need to know how much pain in the @ss dropping the fuel tank will be.My father thinks we will be able to do if without dropping the rear end though removing the exhaust.(but I don't feel like breaking anything that's not on my list to replace.) I'm either repairing the tank or finding a used one. Post pics of the hassle or tricks of doing this, want to get it done in one day nothing more.Also if you know of a place or website of where to buy a fuel tank feel free to post those as well.
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
Re: 1991 Camaro fuel tank
the axle and exhaust must be dropped to get to the fuel tank, look up cutting an access door by the hatch area, even though its a hack job it will save a lot of trouble
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
I dropped mine without having to take off the exaust, just had to remove the 2 bars. hardest part was putting back up ( just myself)
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
oh and i am going to be picking up a 82 z28 and going to be parting it. i am going to be removeing fuel tank to use the fuel senging unit. interested?,
Also, i could be done in a day if you rush it though. while its down i would clean the tank and units with tank cleaning solvent and lube everything up to get it tip top shape bro.
some people have said that they where able to slide the tank out at an angle, the tank has a lil bit of weight to it. I dropped my whole rear and exhaust when I did it tho... not impossible
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
wow thats amazing, i would like to ask how did you do this? and how can i go about to start this, im going to be dropping my tank again ( to fix my fuel float) and ill probably need to replace the pump again one day (because im turboing my v6)
Engine: 5.0 TBI
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Not mine. Just a pic I found no telling how long ago. I saved it for future reference because despite knowing that I have posted that exact pic before, people (somehow) don't see it.
Car: GTA
In fact...The 4th gen tanks are a physical fit too which are only "limited" by their fuel pump & fuel lines.
Engine: 5.0 TBI
ALL 1982-1992 Camaro & Firebird gas tanks physically interchange. The only differe is 2 things...The pump inside, or lack of on EARLY carb 3rd gens that might have had the block mounted pump, & the 1LE tanks with the baffles inside.
Car: GTA
So if I wanted to do the 4th gen tank or ls tank.Will I need to change my harness, i have the 5.0 TBI.I know the ls tank has the evap system which will do me good in emissions test. But I still have unknown questions cause im not use to the 4th gens yet, post reliable sources or people also diagrams and such if possible, thanks for the help.
i know ive actually done it to my car haaa. but everyone that see it says its a hack job, but seriously it saved me SOOO much headache so i dont even care, just flop the carpet back over and it looks like nothing happened
[qGreat job ....Jus how i am thinking of doing it ...im concerened on how flexible the steel lines are to remove the pump ...how much give is there ?uote=BlackenedBird;5259512]No. It is correcting a factory oversight. Besides...."hack job" only refers to HOW it is done. It can be done quite professionally & cleanly. Done with the proper line connections:
Totally professional way of doing one:
[/quote]
[/quote]
Car: GTA
Virtually none. The hard lines will have to be cut while the tank is still in the car to lift the pump assembly out. Or drop the tank to lift the pump assembly with the hard lines attached then cut.
Car: 1987 Trans Am
Engine: LQ9/L92
I have dropped a tank out of a 3rd gen without dropping the whole rear, but it probably would have been quicker if I had. The filler neck goes through a pretty tight spot between body panels and you want all the room you can to maneuver the tank out.
If you have a lot of gas in the tank, you can drain it pretty quickly thanks to the fuel pump wiring to the ALDL port. You can kick on the pump with +12v and disconnect the feed line to the throttle body and pump it into a can from there. no long drawn out siphoning process from the filler neck
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
AkDrifted
08-17-2015 07:45 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
