Spectra Red Spray Can
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I am going to smooth a few areas under the hood of my car. I don't need the match to be perfect as it will not easily be visible behind under the hood and engine. Is there a close match I can get from autozone or a similar store?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Spectra Red Spray Can
If you know the color code no.Dupli-Color Perfect Match has GM colors that match up very good,I know Pep Boys and Advanced Auto carry that brand.
Engine: 5.0 EFI
Why does it have to be Spectrum Red,If they have the GM paint code no.for your car then use that.They only had one Red color for that year.
Engine: 5.0 EFI
Just buy a can of code 75 Red and see if it matches,I mean code 75 Red would be the color your looking for,weather it has a color name or not.
Engine: 5.0 EFI
You can try a place a couple of members bought from,(for our interior finish) BAPS it's in York PA look them up on the web,but you can probably get that from any automotive paint supply,just give them the code and just ask if they mix and put it in a spray can
HoosierinWA
10-07-2015 10:15 AM
Dragonsys
09-25-2015 03:51 PM
