Replacing T-tops help
Hey all im thinking about buying a 1984 trans am, however its missing a T-top. i have access to a used pair for $100, can anyone tell me how hard it is to replace these, so i know what im getting into before i go thru with the purchase.
any and all info is greatly appreciated
Thanks.
Thanks.
1 Post
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Replacing T-tops help
All they do is unlatch and lift off. No real secret about it.
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
where are you located, I have like 5 sets of tops. I'd let go of a set to you for cheaper than that.
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Just measure to make sure, there were 2 different kinds. They are on past posts.
Make sure you get inquire about a KEY with the tops you're buying...otherwise you won't be able to lock them. Chances are the keys are long gone if the car's parted out though, and the fact that your t-top is missing entirely means you won't be able to swap your lock cylinders over (at least for the one it's missing).
ambainb
04-25-2016 09:21 PM
