Driver Door Alignment
Old 04-03-2012 | 10:17 PM
3318RS's Avatar
Car: 1990 RS
Transmission: Built-700R4
Are there any tips or an easy way to align the doors? I have a small issue with the driver door. Gaps are spot on exept the rear lower side of the driver door (basically the bottom of the door to the rocker panel). The door has no play, but rubs slightly were mentioned above.
Thanks!!!
Old 04-04-2012 | 05:58 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Driver Door Alignment
IIRC the bracket for the ground effects trap dirt between it and the ground effects. Nothing else while you have it off tweak the bracket down a little.
Another thing to check would be the striker itself. Be sure the top side of it isn't wore down. BTW Nice car
Old 04-04-2012 | 09:05 PM
3318RS's Avatar
Car: 1990 RS
Thank you for the advice sir & the compliment, I will attempt this on the weekend!!
Old 04-04-2012 | 11:21 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Good to see one in FL!
Old 04-05-2012 | 12:28 AM
Guest
Guest
Posts: n/a
What about getting the top of the door to come alil more inward when its closed? A strong gust of wind flung my door open hard and now I hear alil air getting around the back of the window seal.
86IROC112
08-31-2015 08:00 AM
hepcat620
Exterior Parts Wanted
08-30-2015 08:52 PM
Out-Cast
08-23-2015 07:33 AM
BlackTopKing
08-19-2015 01:13 PM
chevyguy1999
08-16-2015 09:49 PM
