how often does the hood to cowl seal go bad?
Old 12-29-2011 | 09:50 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
im getting all new weatherstripping for my car and i remembered that seal was there and im curious to how often these go bad and need replaced? i havent noticed any water getting into my enginebay besides after it rains or i wash my car and i pop the hood then it runs into it because the seal is away from the body.
Old 12-29-2011 | 10:29 PM
puma1552's Avatar
Re: how often does the hood to cowl seal go bad?
Originally Posted by evilemokid94
im getting all new weatherstripping for my car and i remembered that seal was there and im curious to how often these go bad and need to be replaced? i havent noticed any water getting into my enginebay besides after it rains or i wash my car and i pop the hood then it runs into it because the seal is away from the body.
^^^Sorry, but I see this omission literally at least 5 times a day on this board and it drives me up a wall.
As for the seal, mine is 23 years old and still holding strong, with 23 northern freeze/thaw cycles and 150k miles of engine heat and cowl pressure. Once in a lifetime deal I suppose.
Old 12-29-2011 | 10:54 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
If mine did not break (tore by my rushing) when I did the repaint it would sill be on the car. I replaced all my weather striping due to a repaint, my doors and trunk were a bit worn but the rest was not bad. You should wipe the jambs out when washing your car and wipe the WS to keep it clean. Do not wipe it with Armoral or any type of product since that will surely dry it out.
Old 12-30-2011 | 06:17 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
That single piece of rubber is the ONLY piece of rubber NOT getting replaced on my car unless it gets damaged when I go to do the repaint...
Old 12-30-2011 | 06:24 PM
Engine: L31 350
Alright cool thats good to hear and know. Now if only I knew why the hatch or bottom door weatherstripping goes bad I'd be good
Old 12-30-2011 | 06:28 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Well, I don't know about others, but my hatch strip had a 1" gap between the ends of it where water and such leaked (looked like it came apart at the ends), right in the middle above the tail lights, and my door strips (along with just about everything else) were dry-rotted...
1992 Trans Am
05-10-2023 08:19 PM
Black89TA
Exterior Parts for Sale
07-23-2016 11:42 AM
cougar20th
08-27-2015 09:04 AM
Dialed_In
08-20-2015 02:45 PM
ElPaleterro85
08-13-2015 04:49 PM
