Lower Spoiler. Is it repairable?
Happy Thanks Giving guys. Obviously the PO never cared about parking with the spoiler kissing the curbe. But with all the wear and tear, is it possible to bondo or apply "cat-hair" fiberglass to patch up the hole?
1322161721.jpg?t=1322163981
1322161659.jpg?t=1322161662
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: Lower Spoiler. Is it repairable?
Anything can be repaired...Personally I would check my local craigslist and just see if someone is parting out a 1985-1992 camaro and see if the front spoiler is in good condition. If not, then an auto parts store can sell you a kit for plastic repair that will do the job.
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
Don't use bondo, it'll crack and fall off if/when the spoiler hits anything. What I used was some 3M automix plastic repair stuff (like in the "taking the mystery out of plastic repair" thats on here) and zip ties underneath where it was torn - so far it's held up to being moved around the garage, but I can't say how well it'll hold up on the road yet.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Pick-n-pull/wreaking yard,you should be able to find one that's at least a better candidate for fixing,the one you have is in really bad shape.
1 Post
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
2 ways, you can use a plastic welder (harbor freight 15 bucks) or liquid urethane. I would plastic weld it, then coat with urethane, then sand it smoth
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
evercoat maxim flexible urethane. Check ebay, you can find some great deals on it there. I've used it with a LOT of success for fixing things like that
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
To
Anything is repairable. Just depends if you desire to put the time into it. I spent close to 23 hours total to fix mine. About $30 in supplies. It held up pretty good and to this day of it being in the basement in awkward positions it still has not cracked again.
Anything is fixable if you put the time into it. Is all the damage done to yours in that area? That lip on my old 92 had cracks as you can see on each corner and in the middle. The tricky part was just having it stay in place until the fiberglass dried up. Then it was just sanding it down and doing another coat on the back side for insurance.
1 Post
when you fill that area with the hole in, use a small piece of chicken wire behind the hole for added structure
1 Post
btw.. i LOVE the stick hanging out of the crack
