Bistros on a rs hood
Old 11-22-2011 | 01:20 AM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Hey guys. I got some hood blisters for my car and I don't know how to install them on an rs hood. I removed the hood insulation and you can see where the holes may line up. Bit what I don't know is how the blisters are held on. There studs that come from the bottom of the blisters are not threaded. Can any one fill me in on how they are held on? Thanks.
Old 11-22-2011 | 01:30 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Bistros on a rs hood
if they are stock blisters you need a z28 or iroc hood with louver/blister indents in it for the stock blisters to fit. There was a weird press fit nut on the back of my blisters when I took them off. If they are the stick on blisters for an RS hood I don't know about those so someone else will have to speak up.
Old 11-22-2011 | 01:35 AM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
I got stock blisters. But now that you mention it I think your right, I'll need some type of press fit nut. Oh well I'll just have to figure something out. Thanks.
Old 11-22-2011 | 01:37 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
If there are studs on the bottom you need an IROC or Z28 hood from 85-92. If they are the flat bottom type, I don't know how you're really suppose to attach them. Adhesive spray? 3m adhesive tape?
Old 11-22-2011 | 08:24 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
You'll need to beef up your suspension if you plan on installing two small restaurants on your hood.
Jorlain
Exterior Parts Wanted
06-30-2017 12:04 AM
91TTOPZ
Exterior Parts for Sale
09-20-2016 01:42 PM
Quick Reply: Bistros on a rs hood
