upper door pins ,,anyone tried this?
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi,,,i opened the driver's door all the way,,,removed the weatherstrip and supported the door with a jack and strapped the door with a strap hooked up to the ceiling,,,cut off the large parts of the upper pins ,,punched out the old pins once cut/grinded off,,,unbolted the hinge from the body ...installed the bushings ,,slid the hinge back on,,bolted it back to the body ,,,then bolted the bushings/pins,,,anyone ever try this?
Car: 1991 Camaro Z28
Engine: 5.7L
Re: upper door pins ,,anyone tried this?
I replaced the lower hinge yesterday and despite the upper hinge being a bit loose, it did the job. After looking closer at the top hinge, I wouldn't want to attack it. LOL
Transmission: T5 WC
sometimes there's no choice,,, have to change the upper pins...
Hotrodboba400
12-10-2019 07:07 PM
gta892000
09-16-2015 12:37 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
