shaker scoop on T/A
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
shaker scoop on T/A
I googled it and a company called it bandit II, it was made out of steel like stock hoods. Do any one know where I can find a fiberglass rep do they even sell those or get a shaker form a 2nd gen cut a hole in it and weatherstrip. Thanks for any input.
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
Re: shaker scoop on T/A
your best bet would be to get a shaker from a second gen an cut the whole in ur hood to make it work i seen some on craiglist sell for about 100 bucks
Yeah, used 2nd gen shaker scoops are actually somewhat affordable now that they're finally being reproduced. Definitely the route I'd go. If you want to be really cool though, you'll get the vacuum-activated flapper and somehow get it to work with your car.
I would drill a hole in the carb or intake some where be4 the blades. Put a fitting with a vac hose and at wot it opens that would be my guess its for a friend 15th ann T/A with a 400
dustint209
11-26-2015 12:28 AM
sreZ28
10-22-2015 08:21 AM
