rear hatch ??
rear hatch ??
I have an 87 Camaro with a electric rear hatch pull-down. Did all Camaros with the large rear window/hatch have electric pull-downs? Is there an equivilent manual rear hatch latch that can be use to take the place of an electric one?
Re: rear hatch ??
86 was the first year for the power pull down. Many repair parts can be purchased from the following site (should you be interested in that avenue):
http://www.top-downsolutions.com/
JamesC
JamesC
Car: 86 T/A
Engine: 5.0 TPI
Re: rear hatch ??
The welded in sheetmetal bracket that the latch mechanism bolts to is different from manual to electric. Its not a hard job to change that bracket if you are good with a welder and can layout the position correctly. There may also be a difference in the lock cylinder but that should be easy enough to change.
Street Lethal
04-30-2019 12:14 PM
