Lower door pins holes too loose?
1 Post
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I replaced the lower door pin on my driver side door, and the bushings that came with it fit right into the piece that bolts to the body. But when I put the pin through, the holes in the half welded to the door seem to be too big. Did they wear out? Or did I miss putting something in those holes too?
Thanks! Either way, the new pin did help my door a little.
1 Post
Re: Lower door pins holes too loose?
Alright, i've searched around, and I guess I can drill out the holes and put bushing in those holes too? Do you guys think that would work?
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
ambainb
04-25-2016 09:21 PM
