Hood bouncing on freeway!help?
Car: 1986 Iroc-Z
Engine: 355
So i have a 3 inch cowl hood that i recently swapped my big block hood for. Problem is that on the freeway the driverside front corner of the hood flaps up and down continously.
I know the hood is made of fiberglass because its incredibly light. I want to avoid using hood pins, and was wondering if there is any alternative?
Im afraid that if i continue like this the hood will just flap open on the freeway.
Any help appreciated.
1 Post
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Hood bouncing on freeway!help?
I'm in the same boat. On the highway my hood flaps like crazy and scares the sh*t out of me. I just pray my latch holds :/
1 Post
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
You could try adjusting it. The actual latch has a couple of bolts that can be loosened and there is a small amount of room for up and down adjust ability. If you lower it, it may hold the hood down tighter.
Car: 1986 Iroc-Z
Engine: 355
Well im glad im not the only one with a flapping hood.
Id hate to have to get the hood pins but they are looking like the safest solution.
Ill give the adjusting latch thing a try.
Honestly with fiberglass it's dangerous to NOT have hoodpins. They're light and weak, they can and will just break and fold up and fly off the car at high speed.
It will still bounce if you have hood pins though - there's a little trick for that though. Get some water hose (I used heater core hose) and shove it over the top of the hood pin with the hood up, and then you cut it to fit up against the top of the hood that's pinned on.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
What ever you do get it fixed soon.I had a steel hood on a old ford pick-up fly open doing 65 on the highway. "Almost" a horrible wreck. After that there was no doubt hood pins were going on the Camaro.
There are aerocatch pins, which basically are the same thing, but lower profile and less eyecatching, but they are rediculously expensive. But I agree that the only solution is to pin the corners down somehow. Or if it REALLY bothers you THAT much, you COULD do a multi hood latch setup, 1 on each side I suppose instead of 3, but that would definitely be some fabricating, but with enough money, time, tools, and know how just about anything is possible, and I guess it might be possible to do it for the price of aerocatch pins..
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Some are made poorly or just plain cheap, they are not reinforced well and have no rigidity, they flex way to much. Please for your safety put pins in or take the hood off, the latch will hold but your hood may snap and go thru your windshield. It may fly off and cause a wreck
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Try these.They don't stick up and they look great.I bought them and they came with everything you need and detailed directions.I haven't installed mine yet,I don't have the hood I want yet.
Flush Mount.
http://www.deftracing.com/aerocatch_hood_pins/index.htm
Flush Mount.
Car: '82 Z28
What brand of hood are these flapping ones? My harwood bolt on cowl has shown zero sign of moving around, even at 100+. Even the stock composite hood was fine at 100+.
Car: 1985 Z28
Car: 1986 Iroc-Z
Engine: 355
Thanks for the reply guys.
I dont know what type of hood it is, i just met up with a guy and swapped hoods.
It flaps only from the driverside corner. I think i will end up getting pins afterall just hope thats enough to stop the flapping
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
sjorgens
10-01-2015 07:54 PM
