Fiberglass hood trimming
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
Im about to trim my fiberglass hood. It has about a 1/2" lip that hangs down on the front and sides. I figured I could leave the sides alone since it should slip right down between the fenders. However the front wont allow the hood to meet the bumper cover. Does anyone have any tips for removing this lip before I start cutting?
Car: 1985 IROC
Transmission: A4
Re: Fiberglass hood trimming
I had the same thing going on with mine. I was getting it ready for paint so I marked a line on it with pin stripe and used a belt sander to sand it down. Smoothed the edges when I was done. Looks much better. Good luck.
Car: 92 camaro
Engine: 409 sbc
Did you only sand the front of the hood? Or did you trim the slides also?
Car: 1985 IROC
Transmission: A4
I did the front only, the side on mine didn't have any clearance problems so I left them. On the front I was careful not to go to thin, I am worried about the strenth of the front edge, so I left it around 1/4" to 5/16" thick and rounded the edges good to prevent splitting. I'll try to post a picture today.
Hotrodboba400
12-10-2019 07:07 PM
