Spider web effects on my 88
Old 08-10-2011 | 04:38 PM
Rebelson's Avatar
Car: 1988 Camaro
Engine: 2.8l v6
Transmission: auto
Spider web effects my has cracks over it can I just sand and repaint or is this fiberglass work it's on the hood the fenders everywere
Old 08-10-2011 | 11:04 PM
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Re: Spider web effects on my 88
If you want to do it right, sand the cracks out. Without pics to prove, it just sounds like paint cracking. so If I were you I'd sand them out then repaint.
Old 08-11-2011 | 12:24 AM
Rebelson's Avatar
Car: 1988 Camaro
Engine: 2.8l v6
Transmission: auto
I can get pics tommrow and put them up
Old 08-11-2011 | 03:46 AM
justcallmeclassy's Avatar
Car: 1992 Camaro RS Z03 T-Top
Engine: L98 with TBI
Axle/Gears: 2.73...
Since you said its everywhere my guess its a paint problem. But on mine the po had either been hit in the back bumper or backed into something which caused a very nasty spider webbing due to very small cracking... the bumper appeared to be straight but no amount of painting sanding or filler would cover it, it continued to return after a few days each time.
Old 08-11-2011 | 10:26 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
clean everything with soap and water, then spray with wax/grease remover then sand them out completely. On front and rear cover, ground effects and chin spoiler....clean after sanding then use an adhesion promoter before priming with a flexble primer, then repaint. It's a major PITA, but well worth the effort when your done
jovibuilt
Exterior Parts Wanted
10-18-2015 09:12 PM
SRKLEGIN
Interior Parts Wanted
10-12-2015 08:28 AM
jaridjohn
10-05-2015 08:01 AM
SRKLEGIN
09-30-2015 08:19 PM
Marc Brown
09-28-2015 02:40 PM
