I need some advice on repairing strut tower rust
Old 08-01-2011 | 11:10 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
My drivers side is much worse than my passengers, but I'm going to fix both. What I've just done:
FULL front suspension rebuild, powdercoated spindles and A-arms, energy bushings, LS1 brakes, monroe strut, rebuilt steering.
I'm going to install Founders caster/camber plates, but that'll be pointless until I fix the rust.
Question is should I find a parts car and cut a section off? (this isn't easy because I've been trying for a while) Or should I just sheet metal it?
I plan on removing the thicker top piece by drilling out the spot welds, then cutting the rusted crap out and replacing it. Would you agree? Please, any suggestions would be great. Thanks.
Old 08-01-2011 | 11:36 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: I need some advice on repairing strut tower rust
pop off the factory strut mount and then post pics when that triangle support bracket is out of the way, perhaps hit it with a wire wheel first to clean up the loose stuff and then take a pic so we can see how far gone it is
Old 08-01-2011 | 11:42 PM
Car: '91 LS6/T56/9"
Engine: LS6
Oh it's pretty gone.......it kills me to take it all apart again since I JUST finished the suspension/steering,LS brake swap!
J-money
01-04-2019 10:45 AM
lock1983
Brakes
09-09-2015 10:08 PM
Stryker412
09-07-2015 10:11 AM
!CamaroDave
Members Camaros
09-05-2015 11:39 AM
mrdevontay
09-02-2015 09:04 PM
