Wheel house - floor pans replacement
Car: 1986 Firebird
Engine: V8 305
Hey all,
I am in the process of patching the rear wheel houses and inside rear quarters, and replacing the floor pans on both sides.
Should I remove the gas tank before I start welding??
Thanks for the assistance
Paul
Paul
Car: 1986 Firebird
Engine: V8 305
Re: Wheel house - floor pans replacement
After my day today, preparing the rear wheel houses, and inspecting further. The gas tank will need to be removed. Much to my dismay. The dual exhaust is great hindrance.
Paul
Paul
Car: 87 Fomula, bought new, October 86
Engine: 305 Quadrajet,
Axle/Gears: 9bolt now in, starting on body work
Have you got your bird up in the air, at all? The more room you can give yourself, the more likely you will be to make a good repair and of course, having a fuel tank anywhere near welding is a sure bet for catastophe.
Also, take lots of pics for here and yourself-it definitely helps to keep track of your progress.
Good luck!
Good luck!
Car: 1986 Firebird
Engine: V8 305
Thanks for the reply.
The car is on 6 ton jack stands, I have enough room to roll underneath and do the brake and fuel line repairs. Welding underneath will be a task.
I am making significant progress. My only concern is...if the floor and the braces are cut out, will there be enough support around to keep strength in the structure.
I am doing one floorpan at a time. I will try to get some pix up.
Paul
Paul
