Need help picking out a paint gun
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
Im thinking about buying a paint gun. Im guessing HVLP is what I want. As far as brand, tip size, etc. I dont know what to look for. I would want to be able to spray primer, base and clear with it. I looked at Sharp, DeVilbiss, Iwata, Sata, Binks. I know Iwata and Sata make good guns. I dont want to spend $700 on a gun though. What should i look for? If it matters. The paint is PPG DBU atomic orange.
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Re: Need help picking out a paint gun
Assuming you know how to paint, the better the gun the better the paint job. You don't have to buy the most expensive gun to do it, but it should be something quality. I have two Sata guns. One for primer and one for base and clear (1.7mm tip and 1.3mm tip respectively). You definitely don't want to spray primer and base and clear out of the same gun. You can, but I wouldn't recommend it. If you have to, buy a super cheap gun for primer. Some of your higher end painters will have multiple guns for multiple materials. I got a smoking deal on my guns, but if you shop around you should be able to find a good Sata gun in the $400 range. Search my username for my 91 build thread to see my paint job.
Car: 92 camaro
Engine: 409 sbc
I will check out your thread. For a primer gun. Will it matter if its a gravity or siphon feed? I have an old Binks 7 laying around, but its a siphon gun.
Car: 91 Z28
Transmission: t-56
Nah, for primer it doesn't really matter. You're going to block it down anyways, so the quality of the spray isn't as important.
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Iwata makes an extremely efficient, high quality gun. That will be my next one. I'd buy a used SATA if you're not willing to fork out serious cash, though.
Car: 92 camaro
Engine: 409 sbc
1 Post
Car: 91 Z28
Axle/Gears: Stock
I have a one Sata for base and one for clear and the the cheapest ATD gravity for primer and it works great. Look at DeVilbiss Finishline series for a good gun at a reasonable price.
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Devillbiss makes a great product (not cheap) listen to the advice of never use the same gun for the two applications. I use two different tips, one for the base then another tip for clear. Depends on what you are spraying, the reason for me is I like to burry things under the clear, such as SS stripes or ghost flames. There is nothing worse then seeing a custom paint job and then being able to feel the art work under it.
You can actually bury (fix) a small run when you get really good, hope it goes well for you, good luck.
1 Post
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
I choose Iwata because the air consumption rate is excellent, they spray good (obviously), and it's really just a nice gun in your hands. The price, however... is where things are different. I'll be picking one of the Nova's soon and IIRC it's $670? Somewhere around there.
Certainly, some of it comes down to the quality of the gun... but find someone who REALLY knows their gun well, and you'll get an A+ paintjob every time. Find something you like and stick with it.
& yes... use your crap gun for primer, and your good one for base/clear.
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
I use a C.A. Technologies HVLP "CPR". It's made in America, half the cost of a new Sata, and in my humble opinion sprays better than my bosses Sata. In his opinion, it sprays just as well lmao.
Edit, the C.A. Technologies comes with a 1.3 tip, a 1.5 tip, and a 1.7 tip. I use the 1.3 for base and 1.5 for clear. I use a knock off sears hvlp for sandable primer, and an old husky from home depot for epoxy primers. I also keep my guns exceptionally well maintained, and if need be could spray a decent base/clear with my husky if absolutely had to.
Car: 92 camaro
Engine: 409 sbc
Is there a place online to shop for Sata? Not that im set on buying a Sata, but im having a hard time finding them. I know Eastwood used to carry Sata, but apparently they dont anymore. I have seen Sata on a few sites but it says to call. Are they not available for online purchase? Just wondering.
Also, some guns ask you to choose a tip size when ordering. Would I need more than one size for base and clear?
Car: 1992 RS 6spd
This is the gun I bought.
http://www.jnequipment.com/show_deta...ravity_Fee_Cup
Street Lethal
04-30-2019 12:14 PM
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
92projectcamaro
01-18-2016 08:00 AM
