Fog and Reverse Strobes
Car: 88 Firebird Trans Am
Engine: 305 tpi
Transmission: 700r4 shift kit
Axle/Gears: Posi
hey guys so im trying to put strobes on my fog lights and reverse lights but i want them to work normally and with a switch to strobes. is this possible?
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Fog and Reverse Strobes
Are you going to use a strobe kit that uses separate bulbs? If so? Yeah, it'll still work stock.
If you use a strobe controller that just lights the stock bulbs, the output will not be any kind of strobe effect & more like just a wig-wag lighting.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
If your car is your daily driver you would probably be arrested for imitating a Police Officer.I would be careful about doing that,the police don't take that lightly.Your just asking for trouble if you do that.
Engine: 305 tpi
Axle/Gears: Posi
no im only gonna use them at the car shows thats why i want them to work regular too
Car: 1991 Camaro RS Convertible
Engine: 305 V8 TBI
Axle/Gears: 4.1
I'll repeat what someone else already said. Be _VERY_ careful, even using them at shows. The law varies state to state, as well as province to province, but generally, even possession can show intent to impersonate. Having witnessed the fines and the outcome first-hand, you dont want ANY part of that.
AR
AR
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
