Door Lock Key Code..
Car: 1982 Trans AM
Engine: 305 Single Carb
Transmission: Automatic
Ok guys, I lost the keys to my T/A so I pulled out the ignition switch and It has the key code on the cylinder. So I was able to get a new key cut for the ignition.
I was thinking to try pulling out the door locks to see if the key code is on those cylinders as well. I pulled out the passenger door lock and nothing. The drivers and rear lock is really hard to take out, so wanted to know first if anyone here had any bright ideas on this.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Door Lock Key Code..
Take the lock you took out to a locksmith and they can make you a key.
1992 Trans Am
05-10-2023 07:19 PM
