mini tubbing V.S flaring fenders on a 91 RS
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI, planning on built 400
Axle/Gears: 2.73 stock axles
im planning on more agressive set up than my 305 TBI, 400 sbc, connected to a 700R4, 3.73s in the back. id like to say blast from the past, but the flash of the gas. im humoring myself of coarse. And as the more i think of it, the more i say this thing will prob have more low end grunt, so im not wanting the wheel spin all that much. So if i do go with this mini tub, whats the costs, what will i have to do? And flaring the fenders, ik what i should do, itll prob be cheaper, but idk if i can pull looks off. So please, anyone that has had any experience with there 3rdgen like this, could you help me? Im open to suggestions. I wanna put P215R55/15s on the back
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: mini tubbing V.S flaring fenders on a 91 RS
You can already fit 215/55/15 on the back with out tubing.
Car: 1989 Camaro RS
Engine: mild built vortec 350
Axle/Gears: Stock
If you're looking to avoid wheel spin I would recommend a wider and larger tire. 215/55/15 is actually smaller than the stock size of 215/65/15 or 235/60/15. Your best bet would be the 235's but I would actually go wider to a 255 and you could run those on all four corners without having to tub or flare your fenders. With the wider and lower profile tires you increase your handling and responsiveness. I always thought the 215's were too skinny and look out of place on these cars.
I'm running 255's its somewhat tight but i don't have any issues
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
flares, metal ones anyway, will cost a lot more since you have to spend a lot of time getting the sheetmetal straight, and re-paint the car afterwards.
But again, that tire is tiny, no need for any work to fit it.
1 Post
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
hell with a tire that narrow and short, you shouldnt need anymore power to spin it, let alone even consider modifications
Are you sure you didn't mean 315? then everything would make more since...
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
i made a serious error there guys sorry, i was messed up with tire measurements, and i googled it and thought the 55s meant wider. Idk but someone ik was talking bout those being drag radials. I thought that was tire width, but then i googled it and i found out true tire width and height and all that good stuff so now i got my know how. Sorry bout b4 im really embarrissed bout that. Your running P295s with out any problems? I am currently running P235 75R15s on the back, its a lil high.
Car: 74 z28, 89 IROC, 98 Z28, 91Z Vert
Engine: 383, 350, 347, 305
Transmission: th400, 700R, T-56, 700R
Axle/Gears: 3.42, 3.45, 4.10, 3.08
I been running 275/60/15 drag radials for years, no prob.
I am using the Mickey Thompson Drag Radials, DOT approved, they about 195 a piece, but I have found them for 200-250 a pair in nice used shape between here, ebay, and racingjunk.com
Without modifications I think you can go to 275 width, 75 wall is a lot, esp on a 15" rim, the stock 14" rims had either 70 or 75 walls(can't recall which) for a 15" rim I would probably go with a 65 wall, as for me, I have 225/60r16s on the rear and 215/55r16s on the front, but I had to work around the rims I bought having the wrong tire sizes =/ Wish I had wider, when I buy all new tires for it I'll probably run 245/55r16s up front and something like 265 or 275/55r16s in the back.
yea i feel your pain and thanks i will look that site up! And yea with the P235 75R15s on there, and stock gear ratio stock 305 TBI, around town its chirp chirp chirp
Yeah, I don't have much trouble spinning my pegleg, though its freakishly silent, I swear there is virtually no noise from the tires...
well speaking of the P275/60R15s, i have a moderate looking set, might last for a lil while, wont be pulling no boners with these like 100+ cause they rated steet tires. Atleast i think. 1/2 tread life.. So here they are P275/60R15s and im having them giving to me. My cousin dave comes across these all the time, didnt pay for em, he said i could have em.. Well its a lil off topic but dave my cousin has a nasty 400 sbc, he has four of these, and he was gonna use em for burn out contest.
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
I had 245 35 17s up front and 315 35 R17 on the rear never touched you will have to hammer away to fit a 325 though but can still be done without tubbing it out just an inpact and a BFH (big F**King hammer)
