Lambo Doors? $$$
Car: 88 Firebird Trans Am
Engine: 305 tpi
Transmission: 700r4 shift kit
Axle/Gears: Posi
Lambo Doors? $$$
i been looking for some lambo doors for my bird and on ebay there $1300 thats crazy. so does anyone know a cheaper place i could get them?
Engine: 305 tpi
Axle/Gears: Posi
Re: Lambo Doors? $$$
im making it into a show car, i saw one at a car show with lambo doors and it looked awesome. and my doors are sagging anyway
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
well just a heads up are not alot of people are going to help you here, things like this are looked down on here so i wish you luck.
1 Post
Car: 1988 Pontiac trans am
Hate hate hate, Lamborghini doors on a third Gen is like raping. Lady libery ,for 1300 you can buy 1$ cheeseburgers for 1300 fat chicks and make them happy. Make people. Happy don't **** them off with Lamborghini doors on a third Gen!!!
Car: 1989 Camaro RS
Engine: 2.8l V6
Transmission: Auto 4
1 Post
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
People can hate if they want, but I'll give you +1 for originality. And what he said ^. Most kits are around a grand.
Car: 1989 Camaro RS
Engine: mild built vortec 350
Axle/Gears: Stock
Before this thread gets locked for bashing I thought maybe I could actually help someone looking for info.
Do a search this has come up many many times before. Here's one that actually has a kit installed https://www.thirdgen.org/forums/memb...mbo-doors.html
and apparently this is where he got it http://www.gtfactory.jp/diablo.htm I don't believe you're going to find it much cheaper and I would highly recommend having a professional install.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Ebay usually has kits. Becareful which ones you use some don't have decent shocks. Our doors are pretty heavy. Usually it takes some cutting and welding also.
Car: '85 Sport Coupe/Z28
Engine: N/A 350
Transmission: TH350
Axle/Gears: Factory 10-bolt w/3.08
^^^ Our doors are VERY heavy.
Look into gullwings. I don't think I've ever seen those.
Engine: 383 SBC
Gullwings would be hard since our cars don't have frames around the windows.
Car: 85 TA (sold), 88 Corvette, 02 Monte
I think part of the problem was that the part of the frame where the hinges attach starts to cave in from the weight of those absurdly heavy doors.
Engine: N/A 350
Transmission: TH350
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
I'm not a fan of the lambo doors on our cars either but to each his own.If the guy likes them he doesn't need to be bashed for it.After all it is his car.
Engine: 383 SBC
Most of the lambo kits for our cars I've seen use 2 shocks. I've used lambo doors before on a friends Celica and they were a pain to line up and close due to the fact that they can swing both out like a standard door and up. It's a personal preference. I would recommend a lot of research and you try them first on someones car if possible.
Ya know, previously I'd just been going with the flow, and saying lambo doors suck.
BUT, think about it, and they actually seem *sorta* practical.
I'm not a tall guy, the seat in my TA is pretty much all the way forward, and the farther forward the seat is, the farther you have to swing the door open in order to have the same ingress and egress width between the seat and the door.
No one can deny, our long doors are a PITA in a cramped parking spot or in the garage, and it can be challenging just to get in and out!
See how much room you could have? And come on, it doesn't look that bad.
(I think it was a really bad idea to cut into the inner fender substructure though)
Ariyana Dumon (02-25-2020)
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
gullwings can be done but you need special heavy glass like used on the hatch. since just like it, the hing would bolt right to glass. would even allow mini 1/4 windows for air like euro sports cars.
Car: 1986 Camaro
Axle/Gears: 411
Lambo Doors Look Stupid, Are Played Out & They're Problems, Lining Them Up Eerytime You Got To Close The Door And If They're Not Lined Up Right You Can Damage The Paint And Also Break A Window. Then They F*** Up After Awhile And You Can't Even Open Your Door, You Should Just Save Your Time, Money & A Lot Of You Getting Clowned On. My Boy Had Lambo Doors On His Tahoe & They Were Nothing But Problems.
Engine: 305 tpi
Axle/Gears: Posi
Listen guys i dont care if there played out i always thought they looked nice and different then all the millions of cars out there. Its true what gunmetalgta said its hard to get out of it in a tight spot, i dont see a problem with opening your door up rather then out and i take my bird to shows every tuesday
Engine: 383 SBC
Kit on my friend's car you could still open the doors out like normal. It just had another axis that would allow the doors to rotate up.
Engine: L31 350
told you you would get knocked around on here....i tried to tell youuuuuuu
If it's what you want go for it. I actually like the look but I wouldn't want it on my car. If everyone had the same taste they would only make one color and one style of car.
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
