Those Damn Doors!
1 Post
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Those Damn Doors!
Well im wondering on what I can do or replace to having to slam my doors shut. The door seems to align with everything but I have to slam it shut! I added grease and I still have to push the door hard just to get it properly shut. Help please!
Re: Those Damn Doors!
If its t-tops check the weatherstripping isn't in its way, otherwise try lifting a little bit as you pull it shut, probably sagging even if it doesn't appear to be.
Car: 1991 Z28
Engine: 5.7 TPI
Also, try completely removing the latch mechanism, soaking it in WD40 and completely cleaning it- then relube with white lithium grease. My door feels like new and shuts beautifully, although I am STILL chasing those damn rattles!!
1 Post
Car: Camaro
Engine: 5.7 TPI
This might sound dumb but what's the striker? And What's The bolt called where the door latches on to? It seems to me that's worn out Instead of being round it's somewhat oval
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
That's the striker - on the body side. Has a large allen or torx inset on it - it's adjustable - the hole it's in is larger than the striker itself, thus it can be moved around within the hole.
Mine won't shut properly either, gotta love those old weatherstrippings, first time or two i drove the car, the door was shut but not latched properly...flew open once or twice...that wakes you up...so then i started locking it, but eventually realized the stupid weatherstripping was making it not shut quite right, and i got smart and just roll the window down a smidge to close the door from the inside and roll it back up, less its nice out of course then it just stays down.
1Aauto
Sponsored Vendors
01-09-2018 02:19 PM
1Aauto
Sponsored Vendors
02-08-2017 03:09 PM
