Ground effects hardware 84 Camaro
84 camaro side skirts. On the rear of the skirt there are two plastic disc that hold the skirt to the body. Does anybody know what they are called or what the part number may be? I can't find these things anywhere online.
Re: Ground effects hardware 84 Camaro
Autozone was the first place I checked. Didn't have them. I also tried a company called Aveco with no help. Maybe I will try to post a picture of them to show everyone what i'm talking about.
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
i'm able to get the mfrom a local shop in ct. usually they have them in stock or they are able to get them.
Car: 85 Z28
Engine: 327
How do those discs hold them to body. I have to put mine back together and I don't see how they work
Car: 85 Z28
Engine: 327
So are they supposed to be attached to the ground efx , then attach to car . Because when I took my ground efx off they were attached to car and I saw no way of attaching them to ground efx
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
let me know if those are the part. i havent had a chance to go to the shop. but i should be going there this weekend. hopfully ill get a part number and price for you all by monday.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
No, that is neither the bracket or disc.The bracket is a flat metal piece in the shape of a U.Its actually two brackets though, one for each disc.
Car: 85 Z28
Engine: 327
You wouldn't happen to know what it is called, or what years had those brackets. I looked at and 86 z 28 today and it was different
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
No idea, but they are the early style, 82-84 maybe.GM switched to a bolt on style similar to the gfx on the front fender/bumper.Those brackets have bolts that go thru the qtr panel & the nuts are behind the plastics next to the Rr seat cushion, bigger hassle in my opinion, but the brackets will mount to the earlier gfx.
This is all i could find.
Car: 85 Z28
Engine: 327
so must be 82 thru 85 then because mines an 85. Well at least this narrows me down to parts cars of those years. Sucks. Have been sitting on a freshly painted car for two weeks, but can't put it back together
Car: 85 Z28
Engine: 327
Bringing this back up? Has anybody found out where to buy bracket, know what's it called or have a pic of it?
yo yo old post but maybe you still have contacts looking for 85 Z28 ground effect plastic disc and clips that mount to studs on body for the long side running from front wheel to rear. these are for the rear
Thomas
Exterior Parts for Sale
21
10-07-2015 05:33 PM
Thomas
10-03-2015 05:34 PM
92firebirdchris
08-14-2015 11:56 AM
