How to clean windows?
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
My windows always look streaky. What's the best way to clean them with out leaving streaks? (Type of cloth/spray)
Thanks for any help.
Car: 1983 Trans Am
Re: Overspray on Windows. How to Remove?
Just use some lacquer thinner to get the paint off then wash the window normally and you will be fine. Kepe in mind that auto paint is pretty durable stuff and you will have to put some effort into it. If you are extremely careful you can also use a razor blade on stubborn areas. Thinners will not hurt your glass.
Regards
Jim
Regards
Jim
Last edited by Firebird@42; 05-16-2011 at 10:49 PM. Reason: Needed a more complete response
Car: 1987 Trans Am
Engine: LQ9/L92
glass cleaner as a light lubricant and some patient time with a razor blade. if you go slow and keep an angle, you wont have any problems getting it off. just take your time and make sure you have a nice new blade
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
there's a product they sell at paint stores called gun cleaner (or gun dip)
Ask them, it's supposed to dissolve modern paints
Car: 82 Z28
Transmission: TH350 for now
You can also try razor blades, but use the ones made of plastic. Places like Leevalley sell them. I have had great luck using them for just this purpose.
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
You should keep it on there.
Photo radar will never recognize you....
Nah
Just some lacquer thinner and some quality razor blades like others have said.
Nah
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Glass is really hard. Standard razorblades will work fine, and are unlikely to scratch the glass if you take your time.
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Just did some touch up spray on a couple places on my car. Masked off pretty good but still got over spray, i used a clay bar for on the paint and a razor blade on the glass, no problem.
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
I work at a ship yard and routinely have to deal with overspray on my windows. As the others have said, something for a lubricant (I use windex) and a NEW razor will fix you right up. Don't make the mistake I did one day by trying a previously used razor. I scratched every piece of glass on my car (that I no longer have!) using a 4 day old blade.
As for the and black around the glass... good luck on finding anything that removes overspray from that!
Also I was just talking to a friend last week who said he always uses steel wool as Travis401 mentioned.
Car: 1989 Camaro RS
On the black rubber i beleive naptha thinner will take it off, but be very careful getting it on the paint. And dont leave it on the rubber too long, it will swell the rubber.
I saw it mentioned, but it wasn't blatantly clear....
On the windows, use new razor blades and plenty of them on a wet window. Never run a razor blade on dry glass as you can scratch them easier. Wet glass and fresh blades will do a great job. If you have overspray on other areas, a clay bar also works well. Again, have plenty of lubrication on hand and you'll be fine. I don't know about the rubber areas so if the others say it will work without damaging it, I say try it.
