Removing rear quarter ground effects?
1 Post
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
How do I remove the ground effects on the rear quarter panel of my 92 camaro? I see the metal piece riveted to the body but the gfx are squeezed in there too tight to get out! How do I remove them without ruining them anymore than I have?
Car: 1992 z28
Transmission: 5 Speed
Re: Removing rear quarter ground effects?
get inside the trunk towards were the extra tire is at and there should be some like metal nuts size 11 or 7/16, and you can remove them all with metal piece
1 Post
I was talking about the driver side, I looked on the back side of the quarter panel and I saw little things stickong through, but no nuts on them.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Same idea as est.1992 wrote, just on the other side. You have to remove the rear sail panel and locking compartment area to access the nuts.
1 Post
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Yup, just did this today, at the junk yard. Took a little while to realize how to remove them, but I got it done. Do work SON!
1992 Trans Am
05-10-2023 07:19 PM
92firebirdchris
Exterior Parts for Sale
08-14-2015 11:56 AM
