stripper
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
stripper
best way to strip engine bay?.. thinking aircraft stripper.. but then i had a guy suggest oven cleaner.. never heard of this has anyone else??
Re: stripper
I've never heard of using oven cleaner... I would use a stripper (If you do, then get the rustoleum stuff. Most others are much weaker and do not work as well.) Make sure that the area is well ventilated and as warm as you can make it. (Above 75 degrees.) Good luck!
1 Post
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Re: stripper
you dont necessarily have to strip it. Sand/scuffy it well enough and paint will stick better then straight metal
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Re: stripper
i think the oven cleaner cleans and etches the old paint so once you rinse it off and dry it you can paint it
DTL504
10-13-2003 08:37 PM
redbird_400
Aftermarket Product Review
12-03-2001 08:50 PM
