anyone ever merge camaro gfx?
Car: 84 camaro Z28
Transmission: borg warner T5
i was wondering if anyone has ever ... i guess you would call it merged.. camaro GFX... like the sides of the 92 RS front GFX with the port holes, with the center of the 84ish Z28 front GFX.. is it possible??? opinions??
please gimme ideas... someone respond...c mon
Car: 1985 Camaro Iroc-Z
Engine: LB9
Re: anyone ever merge camaro gfx?
I've always wanted some with the meaner looking center from a 91-92 ground effect and the smooth sides of the 85-90
I personally have never seen it done, but with all the epoxys and fillers and all that other goody bodyshop stuff i know nothing about, Im sure someone talented could do it.
Only problem i can think of is the old school ground effects like the 84's are way shorter than newer style, like half the height aren't they?. Plus they're made to mate up to the earlier bumper covers which have sharper lines.
Car: 84 camaro Z28
i was thinking like cutting the part off that is in front of the tires on the 92.. and molding it to the same area of the 84... couldnt you blend it so it would look good?.. i wish someone had some pics of something similar.. guess ill just have to try it
like this
like this
Car: 1990 Formula
Axle/Gears: 3:73 Posi
I neve rknew there was a difference, until I was parked between 2 Friends 91 RS's
