How does unpainted fiberglass look?
Old 04-17-2011 | 10:00 PM
DrexRS's Avatar
Engine: 305 TBI
Transmission: 5 Speed Manual Transmission
Axle/Gears: Stock
Hello I want to buy this http://www.summitracing.com/parts/HRD-B-12104/?rtype=10. But I don't want to deal with the trouble of painting it. Does it look like carbon fiber a bit or do i need to paint it?
Old 04-17-2011 | 10:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: How does unpainted fiberglass look?
no, only carbon fiber looks like carbon fiber.
fiberglass hoods are generally gel coated, which is a black finish, satin color. it may not be a totally even color, but you can leave it unpainted if you want to. painted would look better IMO
Old 04-17-2011 | 10:11 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Sometimes they are white too. I have a kit car that is white. Bare raw fiberglass parts are a golden tan color.
Old 04-17-2011 | 10:22 PM
//<86TA>\\'s Avatar
harwood is usually black, but yes, often parts are white, grey, ect. dont often see hoods in raw glass form, but i suppose its possible.
Old 04-17-2011 | 10:57 PM
puma1552's Avatar
Just paint it.
Rattlecans are 99 cents.
Old 04-19-2011 | 09:12 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
JMO- thats the ugliest hood i've ever seen, but whatever
Old 04-19-2011 | 09:26 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
^Don't think you needed to come in here to give your opinion. He didn't ask for it.
As far as the OP, I would just paint it with at least rattle cans.
Old 04-19-2011 | 09:39 PM
DrexRS's Avatar
Engine: 305 TBI
Axle/Gears: Stock
Thanks for the help guys! I'm just going to rattle can it and if it looks odd I'm going to take it to the shop.
Old 04-19-2011 | 09:46 PM
Car: GTA
Might wanna talk to the paint shop first & compare the price between painting straight from the manufacturer vs stripping the rattle can paint, then painting it.
I dunno how what it takes for a shop to strip rattle can, then paint it, but that could increase paint cost more than usual.
Old 04-19-2011 | 09:50 PM
//<86TA>\\'s Avatar
yeah, if you are going to ahve it painted at a shop at some point, forget a rattle can paint job, that will cost you money when it come time for the shop to prep your hood, since they will not paint over rattle can paint.
Old 04-22-2011 | 11:50 AM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
FWIW Those parts usually need some work to make them flat and not look wavy.
I use a 2k filler primer and block sand them to get as much of the waves out.
It depends how fussy you are, there are a lot of crappy looking fiberglass hoods on cars around here...
Old 04-22-2011 | 06:07 PM
EvilCartman's Avatar
Car: '82 Z28
First, that is one of the ugliest hoods you can buy for these cars. Second, the black gel coat will not hold up to the elements, it'll fade over time and just look like crap. Spend the money now to have it painted properly. The Harwood cowl I bought several years ago really wasn't too bad in being wavy but I did end up blocking it out. One more thing, you will need to trim the lip around the hood to match what your stock one is like. That lip is left there for shipping.
Old 04-22-2011 | 06:36 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Go with the SS hood! And have a professional paint it.
Old 04-23-2011 | 02:32 AM
puma1552's Avatar
My comment was more tongue-in-cheek, but I'm not surprised.
Let the body shop paint it.
Unpainted fiberglass = looks like crap
Unpainted carbon fiber = looks like crap
Rattlecanned aftermarket hood = looks like crap
Old 04-23-2011 | 07:05 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
all true
but hey, that hood, some rear window louvers, solid centerline wheels and some pastel stripes down the side of the car, it'll be mid-80's style correct
Old 04-23-2011 | 11:18 PM
Car: '82 Z28
Still wouldn't be right. You'll need side pipes, rear wheels that stick out 4 inches and air shocks in the back to complete the look.
91TTOPZ
Exterior Parts for Sale
09-20-2016 01:42 PM
IROCTheHouse
Exterior Parts Wanted
10-26-2015 03:35 PM
