Block Sanding with Long Board
Car: 1986 Camaro Iroc Z
Engine: 5.7L Corvette L98
Axle/Gears: 2.73 Open
Hello,
I am getting ready do sand down my IROC and fix the dents and dings. I want to get the panels as flat as possible so I went out and bought a durablock kit to block the car down. I did some additional reading over the past few days and most sites were saying that its best to use the biggest "long board" you can find to fit the panel you are working on. Then after you get it flat, you can "block down" the car. Here is the issue. I bought the 7 piece durablock kit to do just that. Do I still need to purchase a more rigid "long board" or will the durablocks do it all? Some sites are stating that blocks are not rigid enough to get the panels flat initially... is this correct? or is the durablock kit i bought the proper tool to get it flat the first time?
Thanks,
Dan
Thanks,
Dan
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Re: Block Sanding with Long Board
I'm doing mine with the durablocks only. I'll let you know in a few days because it should have paint on it by this weekend if all goes well.
Excellent, be sure to post pictures.
thanks,
Dan
thanks,
Dan
Anybody else care to comment
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
The 7 Piece set is all you need my guy. We've have restored tons of high dollar cars using just the 7 piece set. I'm sure someone else will disagree.....but I wouldn't waste my money on any more blocks.
ambainb
04-25-2016 09:21 PM
MoJoe
09-24-2015 09:12 PM
gixxer92
09-01-2015 04:32 PM
firebirdta84
Interior Parts Wanted
08-30-2015 09:28 PM
block, board, car, dura, durablock, long, longboard, make, making, ridged, rigid, sanding, sandingblock, sandinglong, techniques
