how to remove pin stripes
How is the best way to remove the iroc decal and pinstriping on the door and both bumpers. I just need to remove them cause the car is getting primered shortly.
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: how to remove pin stripes
I used a razor blade. I just picked on the edges grabbed on and pulled. It breaks off so I just do it again.
Some parts took along time and others came right off....
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i assume they are the decal type , not painted . a heatgun/hairdrier will help a lot peeling them off . just take it easy , go slow & peel them off . then wipe down area with acetone or laquer thinner to remove glue residue . good luck .
Or you could use an Eraser Wheel which you can get from a paint store and put it in a drill.
http://www.paulfrancispaint.com/servlet/Detail?no=114
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
If done on good paint, not all faded, the car will just fine afterwards, with no evidence that the stripe as ever there, like an unfaded stripe left behind.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
two sugestions... I asked the same question over on autobody101 and these are the answers I got
http://www.tcpglobal.com/AutoBodyDep...temNo=MMM+8907
http://solutions.3m.com/wps/portal/3...glNZ5R4RTPNBbl
I don't know, but I was told that spray will not harm the finish underneath
Car: GTA
The Eraser Wheel is what we used at the body shop when I worked Detail & Prep.
http://www.youtube.com/watch?v=HHKN5_UfDik
http://www.youtube.com/watch?v=rOgX9cV2X8k
Go to your auto parts store and buy a spray can called " Sticker Shocker". Spray it on the decal and it will work its way in behind the decal and melt the glue. Any residue left over can be wiped off with your thumb.
Sticker shocker.....I think I seen something like that at autozone. I will give it a try I already got the eraser wheel and it worked great. its just a pain in the you know what on the bumper cover. After the stripes are done I gotta fix the crack in my nosepiece but that's another story.
I might pick up some of that an do an A/B with the 3m stuff and post the results. It wont be until the end of may though, gotta wait until after the roundup to tear apart my car
Car: 82 Z28
Transmission: TH350 for now
If you are going to use razor blades in the process at all get plastic ones like these:
http://www.leevalley.com/US/garden/p...=2,42194,40727
Much less likely to damage the paint.
Hotrodboba400
12-10-2019 07:07 PM
