89 5inch spoiler mod?
Car: 89 iroc z t top
Engine: 327f/t 0.060 489 cam high rise 750
Transmission: 700r4 auto 4 speed b and m shifter
Axle/Gears: 343 possi
89 irock, doin a 2 tone black and orange paint. Have a ws6 hood, want the 5 inch spoiler. Does anyone know what is involved to put on an 89. Do not plan on using the third brake lite
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: 89 5inch spoiler mod?
i plan on purchasing it, just wanted to know if i need to weld up holes, redrill etc. Hopeing someone purchased and installed so i have a better idea. Cuz u know hawks says it wont work!
Engine: TPI 305/ v6
3pc spoiler is a 3pc spoiler as far as attaching to the car. .
The only 'not work' part would be because it doesn't have a/the 3rd brake light (for legality sake) as far as I know.
A search would also produce posts from a few who have bought/installed the hawks 3pc.
Engine: gone
Transmission: gone
Axle/Gears: gone
I believe the mounting holes line up right. People have had problems with actually lining up the 3 pieces correctly. but not many factory ones are lined up right either.
A 5" one would probably look awesome on these cars.
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Im getting the spoiler for my 91 soon. Should look good with the 4 inch cowl. Then I plan on notching the center section out of the spoiler
Car: 1985 Nascar Budweiser IROC replica
Engine: 358 CI .040 11.88 aluminum heads
Transmission: Muncie 4 speed
Axle/Gears: Moser Axles, Auburn Pro posi,410's
My 5 inch spoiler from Hawks fit great, I just had to open the holes just slightly. That picture on their site is a old pic of my car, the spoiler is well worth the money and really gives a racey look.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
The Hawk's spoiler seems to be luck of the draw as to whether it will fit right or be total warped garbage out of the box. I remember a guy here who got one and the middle piece was actually curved, like the top point of the spoiler was curved as if the spoiler was grabbed on both ends and twisted 30 degrees before it cured. But, other guys have no problems.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
That dry break inlet was from Allstar racing, with a lower tension spring.
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
That's some seriously cool stuff.
I'm in Phoenix twice a year, I have a daughter in El Mirage, and Grandkids in Mesa.
I'll try to look you up when I'm heading out that way.
Dennis
Car: 87 RS Camaro
Engine: LS6
Ok, I'm laughing as I look online for female dry breaks, are you running a fuel cell?
me bad....If so I would love to have chat
Dennis
Dennis
Yes, 12 gallon RCI fuel cell.
Car: 87 RS Camaro
Engine: LS6
I modded a Richardson Spoiler off a Hendricks prototype car.
It's 8 inches as it is, I trimmed off 2.5 inches.
It sits about 5 inches above my original spoiler, I had my original spoiler filled on the backside to alleviate the arc shape which would have cracked as soon as I torqued down the bolts on the back.
I added the spiltter supports on the top, to keep the hatch back as a streetable feature, easy to open.
I have since changed out the large hex head bolst to flat heads on the back and have ordered some decaling to clean up the look from the rear, it will enhance it some.
I had a wing, seriously effective, it just looked out of place.
Last edited by dennisschreuer; 01-12-2015 at 03:08 PM. Reason: Added one more pic....
