1.6 rocker questions
Car: 1991 z28 Convertable
Engine: Tpi 350
Axle/Gears: 273 built ten bolt posi
im am trying to install a set of 1.6 rocker ars on my sbc it has ceterbolt heads would i need some guideplates or will it be just fine the cam is stock also thanks
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1.6 rocker questions
If stamped rockers just swap out - leaving all else stock in there in tact. If roller-tipped rockers again, just swap.
If fancy expensive full roller rockers then I haven't a clue.
Why are we asking this in the Body swection - will get way better answers in the tech section?
Engine: Tpi 350
yea i messed up and put it here,and the rockers are full roller
Engine: gone
Transmission: gone
Axle/Gears: gone
if installing on centerbolts. You need self aligning rockers, unless you have guideplates then you can use whatever you want pretty much.
gixxer92
09-01-2015 04:32 PM
LT1Formula
08-20-2015 09:36 PM
