tighting up hood louvers
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
how do i tighten my hood louvers? im tired of everytime i speed up i have to sit there and watch them bounce up and down so i need them tightened, i thought they had bolts on it and broke on of the tabs off near the center of the louver so im not messing with it till i know exactly what to do.
Re: tighting up hood louvers
JamesC
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Many folks remove the louvers, and use 5 minute epoxy to glue small bolts onto the louvers where there are broken studs, let them dry, and use nuts on the underside when reinstalling.
Engine: L31 350
hm..didnt think of that, how much are new louvers?
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
1 Post
Car: 1987 Iroc-z Convertible
normally you can find them around %360 plus shipping(too rich for me,) I used rhe plastic license plate push in fastners from a cord explorer and made the louver kind of concave where the pegs broke off and rough it up and then epoxy them on let it dry completely then use more over the whole base to seal it in and the speed (cheap tin) nuts still fit and since the fastners were a hair bigger it helped to keep them tight.better plsdtic too shouldn't ever get brittle at least no time soon.
1 Post
make sure you clean boyh mating surfaces with alcohol and let it sit for a while to seal on there good and I would recommend 3m tape. The foamy type not thr thin stiff.
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
I use the 3M windshield adhesive. Just figure out where it's lose and squirt a dab or two in there. It sticks forever and it's not impossible to break lose if you have to.
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
