Z/28 Body Kit Question. Need some help
Car: 1984 Camaro
Engine: 5.7L V8 (350)
Transmission: TH350
Axle/Gears: stock
Ok, so i got a 84 sport coupe that i'm upgrading. 350 sbc and 35h turbo tranny. anyways, i was wanting to know if its possible to take the 92 rs/ss z/28 kit and put it on that. i'll have to get the "mounts" for the kits, well at least for the skirts, and idk if i'll have to change the bumber, but i like the 92 style better than the other styles offered for that year. is this possible?
Car: 1983 Z28
Engine: Forged 355
Re: Z/28 Body Kit Question. Need some help
You need to change the following: Full Bumper, kicker on back sides, sideskirts, front nose piece, and the front nose clip on the bottom.
I got lucky and found a perfect 92 Camaro at the junkyard that they just pulled in, and I got the whole set in perfect shape for like $84.
Car: 1984 Camaro
Transmission: TH350
Axle/Gears: stock
thanks man. i'll check my local junkyard to see if they got one. but a 92 kit will work on a 84 without much problems?
Car: 1984 Camaro
Transmission: TH350
Axle/Gears: stock
ok thanks man. but the 92 kit will work for the 84 w/o big problems?
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Yes, but the front/rear bumpers will also need to be changed, and you need the mounting rails under the doors to hold the gfx on if your car doesnt have GFX.
Car: 1983 Z28
Engine: Forged 355
Yes, either 1991 or 1992 have the same graphics i'm pretty sure no matter what model it was. and you do need those door rails which are a pain to get off, you have to take the interior door panel off to get to them.
Terrell351
06-13-2021 01:13 PM
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
