Anyone help with a patch panel?
Car: 1991 Z28
Engine: 5.7 TPI
Seriously guys, I am in need of a patch panel. I would prefer to use OEM material, rather than 16 gauge, since it is easier to weld together... anyone parting a car out that would be prepared to cut a piece off?
Re: Anyone help with a patch panel?
What part of the car are you patching?
Car: 1991 Z28
Engine: 5.7 TPI
The cowl drain on the drivers side has rusted through where it meets the firewall and rotted that part of the firewall too. I need the part of the firewall behind the relays in front of the driver, from where it meets the fender across to between the brake booster and where the wire harness meets the firewall...
I figure I can patch the drain while I have the firewall cut open.
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
I probably have that for you. I have a plazma cutter for some clean edges on the cuts. Got any pics of what you need??
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
