91-92 high rise
Old 02-05-2011 | 11:34 AM
dergafication's Avatar
Car: 89 iroc z
Engine: 5.7 TPI
91-92 high rise
i have an 89 iroc z, i found a deck top and high rise off a 91 z28 primered for 150. if i buy that can i just take off my deck and will this 91 deck and spoiler fit right and match the lines and contour?
Old 02-05-2011 | 01:26 PM
89chevycamaroRS's Avatar
Car: 89 Camaro RS / 02 Silverado Z71
Engine: 1999 LS1
Transmission: 4L60e
Axle/Gears: 3.73 detroit truetrac
Re: 91-92 high rise
i think you can do that but not sure. i have an 89 rs and i replaced the spoiler with the high rise. i had to drill new holes for the new spoiler and weld the old ones shut. if i remeber right the center ones were really close but didnt work.
i deff made the car look alot better doing that
Old 02-05-2011 | 03:25 PM
Car: 89 iroc z
Engine: 5.7 TPI
Re: 91-92 high rise
yeah but im getting the whole new decklid so im not too worried about center holes, im just worried about the spoiler hanging off the sides or not matching the lines ya know so before i bought the decklid with the spoiler which is off a 91 z i just wanted to make sure it would all line up
Old 02-05-2011 | 04:14 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: 91-92 high rise
The body didn't change between 89 and 91 so the spoiler will look the same on your car as it does on a 91. The problem you will have is that you will need to fill the holes on the rear 1/4 that the side spoilers connect thru. Leaving the old sides on with the new rear spoiler will look stupid.
Old 02-05-2011 | 04:39 PM
Car: 89 iroc z
Engine: 5.7 TPI
Re: 91-92 high rise
ok what about the sideskirts will those line up without too much trouble as well? i was thinking about buying the sideskirts from the 91 as well and i found them for 100 each
Old 02-06-2011 | 12:18 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: 91-92 high rise
The sideskirts arent a direct fit. They will bolt right up to the doors but the bracket that is spot welded to the rocker panel that the top screws go into is different. You can drill the spot welds and weld them onto your car though. I would ge the chin spoiler and the rear bumper cover with the two side filler panels as well if you can. The front bumper cover is the same as the one you currently have on your car. Does this car, by chance still have the hood blisters?
Old 02-06-2011 | 04:42 AM
Car: 89 iroc z
Engine: 5.7 TPI
Re: 91-92 high rise
yes its got the z28 hood with the blisters on it
Old 02-06-2011 | 04:43 AM
Car: 89 iroc z
Engine: 5.7 TPI
Re: 91-92 high rise
i bought the chin spoiler from same person for 100 and the rear bumper unfortunately is one piece but damaged so i might have to look elsewhere for one , but i can always sell the rear bumper off this car which is mint to cover costs
Old 02-06-2011 | 04:31 PM
Re: 91-92 high rise
I would grab those blisters, if only to sell them!
Old 02-07-2011 | 01:47 AM
Car: 89 iroc z
Engine: 5.7 TPI
Re: 91-92 high rise
ha at some point i'll buy a fiberglass hood but my money right now is going towards a block so im keeping the hood but at some point ill sell that ****
Old 02-07-2011 | 06:46 PM
Re: 91-92 high rise
I hear you there!
loud91rs
Camaros Wanted
03-28-2016 05:13 PM
sammy52401
11-11-2015 08:20 PM
oil pan 4
Fabrication
10-06-2015 12:56 PM
Spyder_TheGamer
10-02-2015 01:25 PM
92projectcamaro
09-29-2015 08:07 PM
Quick Reply: 91-92 high rise
