92 Camaro fog lights
1 Post
Car: 92 Camaro RS
Engine: 3.1
Transmission: Manual
I have a 92 camaro and i just bought the bowtie.i wanna put in some fog lights in. if i get after market lights do i need anything eles or what is needed for my project to work.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 92 Camaro fog lights
For the lights, anything you want to use will work - the factory fog lights are almost impossible to find, and when you find them, they run about $200 for a good working pair - many folks use standard rectangular fog lights from Walmart or whatever. There are factory drilled holes in the car, so you shouldn't have to do any drilling, just use the factory holes.
You can use a factory foglight switch if you can find one - you'll also need the little panel for it, or cut out your delete panel for the switch. You'll have the factory foglight switch harness behind the panel in the dash, but it disappears in the firewall connector (in other words, the wiring is in the car, but not under the hood). So you'll have to run wiring out the the lights from under the dash. Use a relay, so that when you turn on the switch, the relay gets powered, and then runs juice directly from battery to the lights - that way you're not running high amperage wiring all the way from the switch to the lights.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If you can't find the switch, I have some yellow print ones and the factory bezel with the cutout in it for doing this. LMK, Henry
OOPS, pay no attention to this. My mistake
1 Post
Car: 92 Camaro RS
Engine: 3.1
well i am looking down at my car and i show no holes down at the car except two same holes which after a bit of research i assume i need the brackets. pfft ... i guess ill have to hunt for theses as well ....
Car: 91 z28
Engine: 350 tpi
their should be three holes behind the grill, theirs a bar running accross it should be their. If you want them to stick out more you will need a bracket or you could make your own.
1 Post
Car: 92 Camaro RS
Engine: 3.1
yea i found the three holes... the fog light i got has a bracket but it sit way to much inside makes it look funny.... now to head to home depot to fit in or start drilling some holes
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
to use aftermarket fog lights you have to fab some mounting brackets ,really easy
Car: 92 Camaro RS, 25th Anniversary
Engine: 305 cid, 5.0L V8, TBI
Transmission: 700R4, 4 Spd Automatic Transmission
I just upgraded my 92 RS with factory original fog lights. Almost all the materials can be found on eBay with no problem. The bowtie grille and the ramscoops were bought on thrirdgenranch.com brand new. fuse, relay and hardware can be found on any auto parts nearby. It was easier to install if your Camaro's underdash wire are already installe by the factory. TPIparts, inside eBay, have the underhood wiring harness, brand new, and it comes with instructions to install it.
