T Top Installed 86 TA
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Just finished installing a complete seal kit on my 86 TA doors,windows.top,hatch,top glass.
Had a helluva time putting the glass back on the top,really
tight.Is that normal?man they are tight.Well it's raining pretty
good here in jersey and went out and sat in the car and wallah
NO LEAKS.
NO LEAKS.
Engine: 5.0 EFI
Re: T Top Installed 86 TA
1A Auto,complete kit cost $465.95,free shipping,no sales tax.
Had it in 3 days.
Had it in 3 days.
Engine: 5.0 EFI
Also went to GM they wanted $200 for each side,and that's just for the T Tops only.
The set is Metro Super soft that I got
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
you can adjust the receivers where the t-tops pins go, move them up a little and things would be better. But keep in mind the seals will shrink and conform the tops and car a little so even if tey are tight now they will settle a bit, so many just give htem a little time and see hwat happens.
Engine: 5.0 EFI
Thanks,I'll leave the alone for the winter and see what happens.
Went out and checked again about 11 AM and still no leaks.
you know what they say " If it ain't Brock, Leave it alone"
Car: 1987 Trans Am
Engine: LQ9/L92
things will be a little tight when they're first installed, but everything should settle in and mold in place and give you a good seal. but definitely let me know if you have any problems!
Engine: 5.0 EFI
So It's okay for them being so tight?,I'm the original owner and they were never that tight.I was thinking of putting some lube on the rubber at the T bar.
Someone on eBay lists the 8 piece kit for t-top cars for $230 shipped, buy it now. Definitely the route I'm going, I can't justify spending $800 on weatherstripping for a car I paid $400 for.
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
