Door question
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Door question
saw this in another thread and i didnt wanna hijack it.
now how do you guys think it would be structurally if one was to cut out all of that, then replace it with an aluminum X? i was thinking it would be easier to get to the window motor and regulator if anything broke. and lighter as well.
Re: Door question
Mathius
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Door question
How often do you need to gain access to the regulator/motor that you feel the need to do this?
Not to mention those items & others are riveted to that piece of sheetmetal you want to cut away!
Re: Door question
plus i figured for those that want to save weight, this could be an alternative
but you dont think by taking out the outlined, and replacing it with say, impact bars would be ok?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Door question
Re: Door question
Did you mean SMC?
SMC panels are formed by a high-pressure mold compressing a mix of fiberglass, resin, catalyst and release agent. SMC pieces are smoother than press molded fiberglass panels and have a marbled appearance – typically gray in color. Note SMC panels require special adhesives for bonding.
SMC is bit different than press molded or hand laid fiberglass replacement parts for cars.
Car: 1990 camaro RS
Engine: 305 TBI
Re: Door question
Did you mean SMC?
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Re: Door question
The doors are a key part of the bodys rigidity, if you make them structurally weaker you will gain more flex in the body.
Re: Door question
ah well it was just a thought.
did the third gens get the impact bars like in the above pictures in the later years? i'm not sure if my 84 has them
Re: Door question
No, they're SMC which is a type of composite (read plastic with some fiberglass strands in it) and 4th gen's happen to be about 300 lbs heavier than 3rd gens on average, so what made you think they were a good example?
As other users have said above, the inner and outer skin on a 4th gen is SMC, but inside the door you will find inner structural steel beams.
Mathius
Mathius
