door seals
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
door seals
so yesterday i went to open my car door, and just about ripped the handle off because my door froze shut, so i got out a couple blowdryers and went to work, i finally got them open(woohoo) and i noticed the door seal that has the two pins in it, had ripped out, one pin took the seal with it but the other just popped out. now i tried to get the pin back in, but my giant fingers had some difficulty, so does anyone have any sort of idea of how to get it back into the seal?
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: door seals
next time coat your rubber door seals with WD or pam... helps keep them from sticking
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: door seals
yeah i vaselined them after the fact, but i still cant get the little black pin to go into the seal itself to attach it to the car
Car: 1987 Trans Am
Engine: LQ9/L92
Re: door seals
it will definitely help to warm up the seals when you're trying to put the pins back in. when they're warmer, they're more pliable and combined with a little bit of grease , you should be able to wiggle the pin back in
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
