Side skirt badging
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
Side skirt badging
I have a 92 rs but im putting 86 iroc side skirts on I want my rs badges to go on the new effects, how do I remove the badge without breaking them?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Side skirt badging
The old rocker panel emblems/badging I have removed ,and new ones that I have used all were held on with adhesive backing. So I would say "carefully" with a heat gun on low should do the trick. Keep in mind that the emblems are not a hard plastic but a softer material that seems to be a type of rubber. You may not be able to save them. They have been on there for many years and have a tendency to peal in the back.
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
You might be better off leaving the emblems on there and just getting new ones. Then you could sell the old rockers without having to say "needs badges".
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
i agree with ronusmcmma
Or you can use a blow dryer for a while. Then make a hillbilly rig. U take 2 short pieces of wood or metal and tie a thin string to both. Then the string goes underneath the emblem and you carefully pull back until the string is all the way through and out the other side. Then it SHOULD peel off. Or you can heat it up and use a thin flathead and nudge it off. Or just buy new ones for like 10 bucks off ebay lol
Hotrodboba400
12-10-2019 07:07 PM
