Hatch glass alignment This doesn't seem right...
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I noticed this only because my friend pointed this out on his Firebird after bolting his hatch on and trying to a line it. I had recently put my glass on (no deck lid) i got all the gaps perfect. on the passenger side the glass sits in more, on the drivers side the glass is nearly flush with the C-piller i think this is more of a height difference but i cant remember, the gaps are equal around the entire hatch glass but the parts of molded bend of the glass as you can see. im starting to wounder if it was the way they molded the glass one bends in more? not sure but like i said i got the glass to body lines perfect same for my buddy's bird, having the same problems.
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Hatch glass alignment This doesn't seem right...
Those things never fit perfect. Looks like it needs to be slid over to the passenger side. Could also be damage from a rear end collision. Quarters on these cars tend to "blow out" on top. Is the w-strip in? Can't tell in pic.
Yea the weather stripings in.
Car: 1988 IROC Camaro/1993 Grand Prix SE
Engine: IROC 5.7 v8 grand prix 3.1 v6
Transmission: iroc 4spd auto grandprix 3spd auto
It seems like every camaro's hatch in the world always doesn't seem right, mine didn't seem right so i adjusted it a little bit, i know mine wasn't right htough because the deck lid rubbed on the car and caused it to rust, so i HAD to fix it.
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Could the glass be non oem and not manufactured correctly?
Car: '92 Z28
Engine: 350 TPI L98
Axle/Gears: 10 Bolt / 3.23
I'll take a stab at this.
This looks like one of the hatch struts is pulling or pushing your rear glass to cause the lopsided look. Just an idea that one of the two struts is weaker than the other.
Does the rear deck lid sit flush and level as you close and lock it down?
No struts, no deck lid... I have the opportunity of full alignment starting with the glass... no dice.
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
Its actually easy to align those, back / fort, left / right ....i did it, just take the plastic pannel off ..underside top, then u see the 4 bolts, losen them up and slide it over...then u need to align the latch hook and your good to go.
i think to slide left or right, its the ones that bolt thru the glass...can't remember !
yup as i already stated... did that... glass to body lines are perfect except for the part were the glass bends
Car: '87 IROC
I looked at my 86 IROC and it lines up all around, but my friends 88 GTA is just like yours. I am guessing that when you shim the bolts at the top it throws it all gaps out of alignment.
I have no shims at the top... i thought about playing around with the tab were the gasket slips on to... but i haven't gotten that far yet
The glass is perfect at the top were it bolts (glass to body line) left and right side (glass to rear quarter panel)... but not the bend in the glass it self the areas in green are perfect the left and right side of glass dead on not even 1/8" off but when it gets to the bent part of the glass that's a different story
Car: '87 IROC
I guess try some shims and see what you get. I really hope you get it to work out.
if i move the glass right to correct this problem ... then body lines are open up more on the left and close more on the right... right now both sides are even
me too... like i said all play around with it more... but i was just seeing if this was more of a common issue
this is what iv been saying the whole time.... if i move the glass right... to make the bends in the glass even then it throws the other lines completely off... i still don't think your understand the problem the entire glass to body lines are perfect right now... the bends in the glass are not... correcting the bend lines will throw all of the other body lines off...
i guess then there is nothing u can do , only buy an other hatch !
Its the lighting
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i know exactly what hes talking about, both my 89 and 83 have never been wrecked and the glass on both sits a bit funny. on my 89 the top pass side corner is a tad out and no matter how much i shift its out elsewhere.
the way i set my glass is pull the struts and the hatch motor, this way there are no other forces affecting the adj and this is what the OP did. i'v heard many a bodyman say third gen QC wasnt the greatest even stright off the line. i got my glass good enough and im just going to live with it.
